Jetmoto 150cc Starting problems someone help
okay so i got a used jetmoto automatic 150cc quad dont know the year:huh: and it will not kick in the motor to start up to idle, the starter turns on and turns, i put in a new solenoid and a new battery, the spark plug was working that day but doesn't spark now when in the atv, gonna test and see if thats the problem, but i dont think it is and i got a new fuse in it also but the engine doesn't seem to want to kick in when the starter turns any ideas?
Originally Posted by maz21
(Post 3112834)
okay so i got a used jetmoto automatic 150cc quad dont know the year:huh: and it will not kick in the motor to start up to idle, the starter turns on and turns...
(Post 3112834)
... i put in a new solenoid and a new battery, the spark plug was working that day but doesn't spark now when in the atv, gonna test and see if thats the problem, but i dont think it is and i got a new fuse in it also but the engine doesn't seem to want to kick in when the starter turns any ideas?
Maybe I'm not understanding your problem correctly? Also... Make sure you didn't put your new battery in backwards... If you did that the starter will turn backwards, but the starter clutch will not engage (because the starter is turning backwards). The starter motor will just spin and spin... :cool:. |
