Ignition HELP!!!
Old Nov 3, 2012 | 10:32 PM
justinlogue5_0's Avatar
Originally Posted by Jaster94
no let me apologize. you did answer his questions and i should've wrote "with a little more detail". of course then you added more detail. so please allow me to apologize. it was early in the morning for me after working all night. again, my apologies.
No worries man, Its all good!
Old Nov 3, 2012 | 10:40 PM
Default Update
Well that buddy of mine couldn't make it so I did it my self all over again. Took the body off and started tracing wires again. it blended in good but I found it and fixed it!! I don't know why some one did this but they took a house wire and ran it from the battery through the factory harness sheath and ran it up into the starter button. So it had a direct hot wire regardless of the switch positions. I pulled the starter button assembly apart and the factory wire was still there(but cut clean and short) so I sodered a piece to it and heat shrinked my soder joint,then sodered the wire back to the factory spot on the starter button. Put it all back together and everything works PERFECTLY!!
PS-Glad your getting over your flu,cold, funky stuff.
Old Nov 4, 2012 | 06:05 AM
Jaster94's Avatar
that's great! that's better than double bonus on triple coupon day! glad you got it going.....
Old Nov 4, 2012 | 08:31 AM
Thanks man
ultangler
Nov 30, 2024 01:35 AM
EIF
Apr 20, 2017 07:15 PM
kbazzy
Sep 26, 2015 11:26 AM
Sw00p
Sep 24, 2015 02:50 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
