Hard no start kazuma 50
Old Nov 24, 2012 | 06:27 AM
Fmarshall04's Avatar
Default Hard no start kazuma 50
Just picked up a kazuma 50 for free. It's very clean, but did not run. I have solid spark, and am getting fuel into the cylinder. Can't find the kiddy kill switch also the remote box with the antenna had a ton of rust a corrosion in it. Is this box part of or needed to run? Can I bypass it or jump the box. Also anyone know where to get a shop manual looking for electrical and carb info. Thanks
Old Nov 24, 2012 | 06:34 AM
Jaster94's Avatar
you got spark? i'd check compression. may be needing a valve adjustment. a lot of kiddie sized quads have safety interlocks on them. such as the lefthandle bar lever/brake lever must be compressed to energize the brake switch to allow spark. but if you've got spark now while cranking, i'd go check compression with a gauge, not your thumb or finger.
Old Nov 24, 2012 | 06:59 AM
I have what looks like 76-77psi
Old Nov 25, 2012 | 06:01 AM
Jaster94's Avatar
maybe LT80 will see this post. i'm thinking that's a little low, but i could be wrong. you may PM him and see what he says.
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
chinkapin
Jul 14, 2016 06:58 AM
1000gade
May 27, 2015 12:37 PM
dunc_n
Aug 26, 1999 09:32 PM
