Newbie with baja 150 starting problems.
Old Mar 28, 2013 | 09:24 PM
Serrowell49's Avatar
Default Newbie with baja 150 starting problems.
Hey everyone I'm sean just joined up. I just recently got a baja 150 engine has national stamped on it if it helps. Problem I'm having is the motor will turn over and cough but won't fire. Tried pull starting it and got it running and if I feathers the throttle I could close the gap between my self and my buddy. If I pulled the clutch in tho it will die right away will not idle. I've changed plugs and tested that to make sure it was getting spark. (Maybe it's weak?) new plug wire, fresh oil. Just wondering if anyone has more rxpierence with this and if I could get led Dow the right path? Thanks again.
Old Mar 29, 2013 | 10:27 AM
Jaster94's Avatar
so it won't idle and when you give it more throttle, it bogs down and dies? is that what you're saying?
Old Mar 29, 2013 | 01:58 PM
armagh's Avatar
Sounds like the jet in the carb needs cleaning. Maybe it is gummed up.
Old Mar 29, 2013 | 02:03 PM
Jaster94's Avatar
i agree. i was just trying to read a little more closely to what he said. grit, gums, debris. i think it's clogged or partially plugged.
Old Mar 29, 2013 | 02:10 PM
armagh's Avatar
I knew you knew. I read all your posts and have decided you are no dummy.
Old Mar 29, 2013 | 10:09 PM
Jaster94's Avatar
he PMd me and said he lost his piston. this is curious to me. . and armagh, i've read your posts/replies and you're pretty sharp yourself. i learn from you!
Old Mar 29, 2013 | 10:23 PM
Ya if I could post pictures from my phone I would. I wonder if it didn't have a frank in it when I got it and that's why it wouldn't start maybe lost compression??? Idk. It broke in half part of its still on the wrist pin other half I pulled out.
Jun 15, 2015 11:22 PM
traumajunkie
Jun 15, 2015 10:10 AM
JackTheKing
Jun 14, 2015 03:04 PM
Jun 8, 2015 06:45 PM
1000gade
May 27, 2015 12:37 PM
