Swing arm bushings
Old Sep 9, 2013 | 01:40 PM
Zrock's Avatar
Super Quad Patrol
Default Swing arm bushings
Here i thought i had some warn out rear swing arm bushings on the little 110 gio.. Turns out the previous owner replaced them with bearings but never up sized the bolt. Easy fix just need to go find a bolt with about a 1/2 inch diameter to fit the bearings.. Someone was thinking when they fixed the rear to bad they did not finish the job. They almost look the same size of bearing that i used the last time i rebuilt a alternator.. Better than getting brass bushings made up and better than the stockers.. And cheaper you can go to a bearing supply place and probably pick them up for $10 for 2 and probably $5 for a new bolt
Now to fix that pesky carb leak..
Customer Service #1
May 15, 2020 08:46 AM
fd24
Jan 16, 2019 08:59 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 19, 2015 06:34 PM
