engine type?
hey people, was looking for an engine model on a kasea atv 2001, so i can determine what engine size, 50cc or the 90cc, anybody have any luck with that, all i see is a frame vin and an id #on top rear engine above clutch.:huh:.
Look on the side of the cylinder. Should say 49 cm3. Generic type engine that was used in the first Polaris youth models and Etons also.
thank you opt, i will take a look at it tomorow.
If it says 49cm3 than it is the 49-50cc correct?
Yes,it's considered a 50 cc machine.
thank you
i have another question for you, do you know how to wire in the cdi to the stator? the plug on the 2 wire stator was cut but there is still a 3 wire plug, do i just connect the wires from the 2 plug stator end to the one on the cdi? i just want to kick start it
See if this helps even though it's Chinese not Korean/Taiwanese wiring diagrams. Hooper Imports Experts on Chinese Motorcycles and Parts, Engines
OPT i found a way to wire in the cdi from a site called G-force, they have been very helpful up until now
http://www.ebay.com/itm/281145674407...84.m1497.l2649 this is the cdi i picked up i wired it the way the post told me to and when i kick over the kasea the light on the side lights up with every kick, i have yet to get it started being that it was sitting for quite some time, any suggestions to help from having one leg bigger than the other, i still have the starter connected maybe i can jump start it that way? |
