Predator 260 overheating issues
Old Jan 2, 2014 | 07:41 AM
hunter14's Avatar
Default Predator 260 overheating issues
I bought my kids a Chinese Predator quad for Christmas and it overheated the first time they drove it. The hose coming from radiator going to motor is hot and the return hose from the engine to radiator is cold. What would be causing this problem?
Thanks,
Tom
Old Jan 2, 2014 | 09:24 AM
Zrock's Avatar
Super Quad Patrol
you sure its a 260? i can find info on 250 and 300?
How do you know its overheating? Pull the rad cap off and let it run it may have a air block in it. Or thermostat may be faulty
Old Jan 2, 2014 | 09:32 AM
hunter14's Avatar
Thanks for the reply, the guy that I bought it from said it was a 260. Its possible that it might be a 250. There is a red temp light coming on after it runs for a bit.
Old Jan 2, 2014 | 05:32 PM
brumbear's Avatar
thermostadt is sticking replace it
Old Jan 3, 2014 | 10:30 AM
Zrock's Avatar
Super Quad Patrol
pull the thermostat and toss it in a pan of boiling water and see if it opens before you just replace it. Could be thermostat, could be pump, could just be a simple air lock or plugged rad. You can probably just run without it. just will take longer for the engine to warm up
MikeyBoyesq
Aug 10, 2015 11:11 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
1966F100
Jul 12, 2015 03:08 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
