hanma 110l not starting
Old Feb 22, 2014 | 10:11 PM
dman85's Avatar
Default hanma 110l not starting
I'm new here so bear with me. I just picked up this quad not running. I've been checking for loose wires and that sort of thing and I found a 9pin plug with 7 wires but its not connected to anything. it looks like it should connect to something just behind the starter but cant figure out what it was. Anyone with any suggestions?
Old Feb 23, 2014 | 07:07 AM
brumbear's Avatar
Make sure your cdi is plugged in look under the fuel tank for a small box black usually possibly even wire tied onto the frame spar, make sure it's plugged in.
Maybe something like thisName:  CDI.jpg
Old Mar 2, 2014 | 08:50 AM
DieselCash's Avatar
Trust, But Verify
Does this quad have the alarm on it? I have seen people unplug these to keep the battery from being discharged. But, this should not keep it from running, supposedly. I should try this on mine.
The CDI picture above should be helpful, try it. Plug it in and let us know what happened.
Does it turn over?
Does it have spark?
Is there clean, fresh fuel in the tank making it to the carb?
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
