bashan not starting
Old Apr 27, 2014 | 01:12 PM
daisy-may's Avatar
Default bashan not starting
My bashan 200 isnt starting. Had it runnimg this mornimg amd set the carb up. Went out for a ride to have some lunch and when i wemt to come home it wouldnt start. What is best to start checking
Old Apr 27, 2014 | 02:21 PM
Swiftyyy's Avatar
Well.. be a bit more accurate on the 'it doesn't start', that might be a good beginning.
Does the starter turn it over? If not, there's your issue, check your battery.
If it does then you need to check if you've got a spark.
Those would be the absolute first things.
Old Apr 27, 2014 | 02:29 PM
daisy-may's Avatar
It does turn over. Havent checked spark yet as it was runnimg fine first thing this morning. Went out for lunc and as i pulled up at the pub it cut out. Hasnt started since but does turn over. Have noticed the fuse coming off of the battery is wrapped in foil for some reason. Almost to bypass it!! More bodges that ive now found
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
