Fire on Hy Bird 200
Old Jun 16, 2014 | 08:36 AM
cubano222's Avatar
Default Fire on Hy Bird 200
Have had this Hy Bird 200 for 6 years & never had a problem with it. While riding it this past week end, it started smoking real bad. I stopped & noticed that there was flames under the shroud toward the left front, next to the gas tank. I put it out using a bottle of water I had but it would flame back up. I disconnected the battery & it stopped flaming up.
Did not burn any wires. The part that was hot & flaming looks like a square metal part with like fins on it. Looks like a radio transformer.
Can anyone tell me what this is & where I can get a replacement. The motor will start but I don't know if that part will over heat again.
Thank you for your help,
Jerry
Old Jun 16, 2014 | 09:31 AM
Jaster94's Avatar
does it look similar to this? if so, it's the rectifier.
you'll need to replace it. of course there's always ebay, but there are some other online parts dealers if you don't have a dealer nearby.
Hi Bird ATV Parts
Old Jun 16, 2014 | 11:22 AM
cubano222's Avatar
Default FIRE on Hi Bird 200
That's it exactly. What would cause it to catch on fire? Does one size fit all?
Thank you so much
Old Jun 16, 2014 | 01:48 PM
Jaster94's Avatar
internal malfunction-it couldn't cool itself so it needs to be replaced.
ultangler
Nov 30, 2024 01:35 AM
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
IMLN
Sep 28, 2015 03:32 PM
Elkaholic
Sep 6, 2015 02:44 PM
