Chinese ATV no spark
Old Jun 21, 2014 | 09:01 PM
mpwells00's Avatar
Default Chinese ATV no spark
Hello all I am at my last straw with this ATV it has no spark
I have put a new battery in as the old one was bad I have changes the stator checked the plug and the coil I can't find a wire diagram for this model on the cdi I have 4 wires on one side and 1 wire on the 2 pin connector as well as a 4 wire regulator. I have 12 vdc going to the cdi but I have no volts to the coil I have checked the wires that go from the cdi to the coil and all seem fine I ordered a new cdi that was a DC plugged it in and tried Turing it over. Once I let up off the ignition switch the new cdi started smoking and blew the fuse. I put a new fuse in and the original cdi and everything turns over but still have no spark. Any help would be appreciated.
Old Jun 21, 2014 | 09:43 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Is atv dc ignition or ac ?
Old Jun 22, 2014 | 09:46 AM
mpwells00's Avatar
I want to say its DC I have tested the wires going into the cdi and have 12 vdc
Old Jun 23, 2014 | 11:07 AM
Jaster94's Avatar
wow, please elaborate on which quad it is. can you tell us make/model? it is hard for me to imagine dc being the norm. i would venture to say it should be ac. we have lots of wiring diagrams, but need more information about your quad if available. did you buy it new? when it was running, did the lights stay dim until you revved it up? how did it fail you? we need a little history if at all possible.
Old Jun 23, 2014 | 12:40 PM
mpwells00's Avatar
It is a 2006 sihray 150cc is all thr info I can find it has never ran since I got it. It was given to me I have no history on it at all. I am not able to get any vac readings at all its all dc from what I can tell and the info I was give to determin if it was ac or dc.thanks
Old Jun 24, 2014 | 02:21 PM
Jaster94's Avatar
do you mean SHINERAY quad? LynnEdwards has an excellent write up about how to tell if it is ac vs dc. it is listed in the chinese section of the forum. read that thread and it'll help you determine which is which and what you got.
Old Nov 14, 2014 | 11:12 AM
mpwells00's Avatar
OK well so far nothing has worked to get this thing running I'm out of ideas. Ive replaced the cdi the coil the stator a new battery and still nothing any help would be great. Thanks
Tomtom86
Aug 7, 2024 07:40 PM
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Waddell4436
Jul 20, 2015 09:46 AM
Unzzy66
Jul 11, 2015 10:01 PM
