mad cat 110 wont start help !!!
Old Jul 24, 2014 | 03:31 PM
Jake Dunne's Avatar
Default mad cat 110 wont start help !!!
right so , my quad started backfiring and spluttering while i was driving with just a bit of throtle so i took out the carb cleaned it and put it back in and it still spat and backfiring . i replace the carb and now it wont start iv charged the batt full and stuff shes turning but not takeing off . any help any1
Old Jul 25, 2014 | 02:42 AM
Jaster94's Avatar
even though you replaced the carb, is there fuel in the float bowl making it through the jets to the cylinder and getting the spark plug wet with fuel? have you tested for spark? you might've degraded a wire feeding spark when replacing carb.
Old Jul 25, 2014 | 03:04 AM
Jake Dunne's Avatar
yes there is now but the first carb the float was sticking so i taught it was the cause and iv also replaced the ignition coil and the spark ?
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
