110 loses spark after 2 minutes
Old Aug 23, 2014 | 03:37 PM
ringosmash's Avatar
Default 110 loses spark after 2 minutes
Hi. I have a 110 with a new cdi, coil and voltage regulator. When it is cool it will start right up but, after it warms up for just a couple of minutes it will die. I immediately check and there is no more spark.
What could cause it to lose it's spark like this? Might it have something to do with the stator or spark arrestor or something?
Thanks.
Old Aug 23, 2014 | 03:40 PM
Swiftyyy's Avatar
The first thing you should do is try it with a new spark plug.
Also, after it dies, are the electrical components hot to the touch?
It could also be a bad cable leading to the plug.
Old Sep 10, 2014 | 08:57 PM
Like to ride's Avatar
Any update to this thread? I am interested to learn of the fix if there is one. Could this be a bad coil? As mentioned above, sounds like the ignition coil might be bad?
Divergent12
Dec 30, 2017 08:33 PM
mtdewmn
Jan 19, 2017 12:13 PM
Stirling
Aug 9, 2015 01:49 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
