weak spark w new parts
Old Oct 18, 2014 | 11:15 AM
bamax100's Avatar
Default weak spark w new parts
Atv has been sitting for 1-2 years. after some work,i have it turning over but have very weak spark. Since I had new parts laying around,i tossed on the cdi and coil. still weak spark. with the age,its a 2007 panther 110, and sitting for years cause the stator/coil to just not fire enough?
Old Oct 18, 2014 | 11:32 AM
Swiftyyy's Avatar
How does the cable leading to the plug look like?
If it's in bad condition, that's likely the problem.
Old Oct 18, 2014 | 11:48 AM
bamax100's Avatar
coil with plug is new
Old Oct 20, 2014 | 11:34 AM
Zrock's Avatar
Super Quad Patrol
Check all your connections to everything. I found i had a wire on the back of the key switch that only had 1 or 2 strands of wire holding it. This was after i had pulled the whole wire harness apart and redid every solder joint in it.
Old Oct 28, 2014 | 09:41 PM
bamax100's Avatar
wire from stator came loose at the connector.didnt see it because of the body and frame. easy fix
chammerbeck
Jul 17, 2015 08:06 AM
Unzzy66
Jul 11, 2015 10:01 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
Jkfx400P
Jul 6, 2015 10:04 AM
Elad Cohen
Arctic Cat Side By Sides
Jul 4, 2015 02:26 AM
