bad stator?
Old Jan 19, 2015 | 08:01 PM
bdelancy's Avatar
Default bad stator?
what are the symptoms of a bad stator will you loose all power I have power to my battery and to the solenoid but past there nothing
Old Jan 19, 2015 | 10:21 PM
MPDano's Avatar
A Stator is the same as a car alternator. Does your ATV have a kickstart? If so, disconnect battery and give it a kickstart and if you got spark at your plug, stator is fine.
Or if you can start your ATV with battery connected, start it and let it idle and then disconnect the neg cable on your battery, if it continues to run, stator is fine.
Old Jan 20, 2015 | 11:47 AM
bdelancy's Avatar
no i dont have a kick start and it is getting spark im lost here
Old Jan 20, 2015 | 02:25 PM
MPDano's Avatar
Jump the solenoid by using a screwdriver across both posts on the solenoid. does the starter turn and ATV start?
Old Jan 20, 2015 | 02:27 PM
bdelancy's Avatar
no that doesnt do it either just a mild spark then nothing it doesnt even try to turn over
Old Jan 20, 2015 | 02:29 PM
bdelancy's Avatar
it started last night when i jumped it then i cleaned the carb reassembled hooked it back up to the cables and thats when i lost all power to the whole bike i have full amps at the battery and solenoid but no power to the machine
Old Jan 20, 2015 | 07:36 PM
MPDano's Avatar
By jumping the the solenoid, your putting full power of the battery to the starter. Are you sure it's not flooded now? Remove the spark plug and try again. This will push fuel if any out of the compression chamber.
Old Jan 20, 2015 | 07:40 PM
bdelancy's Avatar
There is no power past the solenoid now no lights no indicator light for gear selection nothing
Old Jan 20, 2015 | 07:47 PM
MPDano's Avatar
Trace your wiring and see if the is a fuse holder somewhere or loosely plugged in connectors. Usually it's the last area you were working on that is suspect. Carb is center to your ATV, check around there.
Old Jan 27, 2015 | 07:16 AM
bamax100's Avatar
battery dead?
