no start and backfires through carburetor
Old Feb 26, 2015 | 06:56 PM
billye's Avatar
Default no start and backfires through carburetor
Hi I'm new to this. I'm a heavy equipment mechanic and this little engine is kicking my ***. I have my dads 03 polaris sportsman 400 that I can't get to run. The bike sat for awhile. Not sure how long. I cleaned the tank and redid the whole fuel system. New pump, carb and filter. The bike didn't have spark at first so I installed a new stator and pulser coil. Got the spark back now but can't get it to fire up. Every so often I will crank if I hold the throttle wide open but will run about at low rpms and not build and if I let off it will backfire through the carb. I checked the timing and it seems to be right. Not sure what the compression spec is but I'm getting 95psi and then I put a bit of oil in the cylinder and jumped it up to 110psi. Sparkplug is new. So wtf is going on with this thing. Oh yea I've even checked the throttle switch and no change either with the contacts touching or not. Please help!
Old Jun 30, 2018 | 08:12 PM
Shootyourface30's Avatar
Unhappy Be careful
I’d be careful man I just got a 1996 Polaris 300 xplorer and it caught fire today after a back fire through the carb
Hankey Pankey
26
Oct 18, 2020 03:50 PM
Ringwood
Jun 27, 2015 03:02 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
