carb adjust every time?
Old Oct 24, 2015 | 09:36 AM
pfcfreeman8's Avatar
Default carb adjust every time?
i have a brand new 200cc Chinese atv and i have to adjust the screw every time i ride. it starts out screwed in all the way then gradually unscrew for about a 1/2hr till the idle is normal. iv tried adjusting the choke instead but that didn't help. your thoughts?
Old Oct 25, 2015 | 09:50 AM
Zrock's Avatar
Super Quad Patrol
is the spring tight that holds the screw in place? Might have to stretch the spring a little bit.
Are you sure the choke is operating correctly? Idle should not be adjusted until machine is up to operating temp and choke is off. Manual or electric choke?
Old Oct 26, 2015 | 04:42 PM
its a manual choke. i start it with the choke out and carb screw adjusted to high RPM's. butonce it starts i push the choke back in and it wont stay running without throttle 1/2 way.
Old Oct 26, 2015 | 04:51 PM
Zrock's Avatar
Super Quad Patrol
The choke needs to stay on or partially on until machine warms up.
Old Oct 27, 2015 | 07:50 AM
MPDano's Avatar
Blocked Pilot Jet. Remove the bowl from your carb and clean both main and pilot jet. You should be able to see light thru the holes.
2001YamahaShee
Oct 22, 2015 12:09 AM
Matthew James
Oct 19, 2015 11:43 AM
ed palmer
Oct 18, 2015 03:03 PM
