Meerkat Starting Issues
Old Nov 29, 2016 | 12:30 PM
heyron33's Avatar
Default Meerkat Starting Issues
Hello All
New here and grasping straws.
Picked up a free Kazuma Meerkat 50cc that wont start. So did the normal. Has great spark. Took the Carb off gave it a good cleaning. Made sure its getting fuel. Adjusted the valves .004 from what I have read. Is that correct? Still not starting. I did a compression test on it last night and its showing only 60 psi. So im wondering if the valves arent set correct. Can anyone shed some light on this for me. I would greatly appreciate it along with my daughter when she gets to ride it for the first time.
Thanks
Aaron
Old Nov 29, 2016 | 01:15 PM
DirtDevil101's Avatar
Try this...
https://riacrewnygi.files.wordpress....erkat-50cc.pdf
If not then new piston/rings may be in order...
Old Nov 29, 2016 | 01:32 PM
heyron33's Avatar
Link is broken. Any chance it might be at another location?
Old Nov 29, 2016 | 03:21 PM
Just do a search for Kazuma Meerkat 50cc valves...
