Won't maintain idle
Old Dec 25, 2016 | 07:39 PM
Fastest1's Avatar
Default Won't maintain idle
Hey fellow atv'ers. I have a 2015 CF Moto 500 CForce. It has approx. 125 miles. My problem is that after I start it up, it'll run for around 30 seconds then shut off. As long as I keep throttling the machine, it'll run. I've taken it to the dealer and after reading a code, they determined it needed some type of sensor. They replaced that sensor along with the spark plug. Still doing same thing, shutting off. They're baffled. Anyone out there having or had similar issue? Certainly appreciate some feed back.
Old Dec 26, 2016 | 08:56 AM
Zrock's Avatar
Super Quad Patrol
Since im assuming this is a efi machine. Check your battery voltage until the unit stalls. Battery or charging system may be putting out low voltage. Pull the plug after it stalls and see if its wet may be flooding out.
Old Dec 26, 2016 | 05:48 PM
Fastest1's Avatar
Well I got a call from my dealer today. He's tried his best to remedy the problem and has contacted CF Moto. My dealer is sending them the ECU which he says is the brain of the machine. I've even sent CF Moto an email asking that they'd expedite the repair. I want the machine repaired correctly, but have a planned hunting trip scheduled in two weeks. Gotta have the bike back by then, heck that's the main reason I purchased the dang thing. To old to be dragging deer out of the woods.
