Coolster 125cc Cuts Out at Full Throttle
Old Jan 13, 2017 | 08:07 AM
smithder's Avatar
Default Coolster 125cc Cuts Out at Full Throttle
I bought my son a new Coolster 125 for Christmas. It starts easily, idles nice, and runs good until you really give it some throttle. Any sudden throttle over about 3/4 will cause it to die out unless you back off. I noticed if I give it about half choke it doesn't do this.
I assume this this means it is starving for fuel. It's has only had about two tanks though it and always treated with sea foam. Do the make bigger jets? I read one post where folks were drilling the jets. It there a known fix for this?
Thanks
Old Jan 13, 2017 | 09:35 AM
Zrock's Avatar
Super Quad Patrol
I would check the float level. If its set to low it will starve for fuel at higher speeds
Old Jan 13, 2017 | 10:41 AM
smithder's Avatar
Do you know how you check the float level?
Old Jan 14, 2017 | 09:28 AM
Zrock's Avatar
Super Quad Patrol
if you search this forum their is lots of info on the subject
Old May 14, 2021 | 01:25 PM
Randy Jent's Avatar
I have one that dose the same thing. Any solution for the prblem?
Old Dec 16, 2025 | 09:13 AM
SlimJim1955's Avatar
Cool coolster
Hi, I have the same engine and have had this problem before. One thing to check is your main jets. The way to check that is by going into the carburetor bowl, taking out the screws inside the float, and inserting something like a paperclip through the small holes to clear them out. Then, once you have confirmed they are clear, put some carb cleaner down the top of the screws. Finally, put the jets back in, and it should run nicely.
