Slowww Cranking
Old Mar 3, 2019 | 11:38 AM
JohnH2018's Avatar
Default Slowww Cranking
I have a 110cc Chinese quad with a Gio engine. When it’s Warm it cranks & starts up great. When it’s below freezing like - 20 degrees Celsius or so it’s very slow to crank. I tried to use a good car battery with booster cables & also tried a fully charged booster pack. I attach the cables like this - positive red cable direct to starter positive terminal & black negative direct to a good ground near the starter on the engine. Still cranks way too slow to start. Anyone know how to make it crank properly when it’s Cold out ? Thankyou
Old Mar 3, 2019 | 01:05 PM
Yoakum's Avatar
Living in Texas, I think 20 degrees above zero is cold
What weight oil are you using at that temperature?
Old Mar 3, 2019 | 01:21 PM
JohnH2018's Avatar
I got some 0W30 to try
suzukiyamahaman
Sep 29, 2004 12:58 AM
TJw6981
Nov 16, 2003 09:21 PM
DeuceRooster
Nov 15, 2003 10:06 AM
85lt250r
Oct 13, 2003 03:25 AM
