Tao 250 Rhino revs up by itself
Old Sep 21, 2019 | 09:56 AM
Ski Zawaski's Avatar
Default Tao 250 Rhino revs up by itself
Every time after riding for awhile, the engine revs up by itself. Usually when I'm slowing down coming to a stop. The throttle cable has a clear run to the carb, no binding or kinks. I pull and push the cable to see if that helps but does not. Any ideas??
Thanks!!
Old Nov 25, 2019 | 04:51 PM
graysons110cc's Avatar
Thanks!!
Have you tried adjusting the Idle Screw? If it's Idled up to high the engine will rev high.
Old Nov 26, 2019 | 07:48 AM
The problem was the cable was riding against the spring in the carb body. Turning the spring did the trick.
Old Nov 26, 2019 | 09:21 AM
Ah yes. First time putting my sons carb back on I put the the throttle spring loaded black slider in 180 degrees the wrong way. When I fired his atv up it was instantly wide open throttle lol. Glad you got it figured out.
Ski Zawaski
Sep 23, 2019 02:07 AM
SOLOLUCKY
Feb 23, 2018 01:07 PM
roughrider1
Feb 7, 2017 08:08 PM
butler8311
Aug 1, 2016 08:59 AM
butler8311
Utility ATVs
Jul 30, 2016 04:13 PM
