Tao 110 no forward power..
Old Nov 3, 2019 | 09:20 PM
Mike721's Avatar
Default Tao 110 no forward power..
Hello to everyone. Please help me out here. Bought a used 110 for my daughter.. Wanted 1 i could fix up... i got that & a whole lot more. Had to replace the forward gear due to old 1 was shattered, laying in case. During that repair saw scored cyl walls. Blah blah new cyl & piston & rings. Heres issue.. its only got 1 forward & reverse gears. Auto clutch. The damn thing, will light up tires in reverse, but forward is way dif. It bogs & takes long time to get going. & if you try to start going over bump or uphill, might as well take a lunch & check back.. lol. Ive got a new clutch, new carb too. My compression is 150. I locked itt at TDC on compression stroke & put my air nozzle in plug hole, & cant hear obvious leaks. I know reverse is geared lower giving more torque than forward but this is more than that. I havent checked exhaust pipe to see if its restricted. This thing was spitting oil out pipe before. My timing is right on. Otner than exhaust being clogged only other thing i can think of is valves, but wouldnt i have heard air leaking when i blew air in cyl? Or is this how the single speed performs? Im 190lbs. I expect it to not move to good if im on it, but my daughter is 10yrs & cant weigh more than 60lbs. Today, the little shSpam wordSpam word Spam wordSpam word Spam wordSpam word Spam wordSpam word was riding in reverse cause its more fun. So this cant be how it should perfom right? I gotta replace valve seals cause i believe they're letting some oil slip into cyl. Doesnt smoke all the time or badly.
Im looking now for either a 80-125 cc manual clutch 2 stroke w/ gears 1-5 or 125cc 4 stroke with man or aut clutch & multiple forward gears. Can that be be the issue? Only 1 gear, so it sacrifices torque so it can top out higher mph? Help please..
95posportsman400
May 10, 2024 10:08 AM
Abdulrahman Boutaleb
Mar 9, 2018 10:44 AM
laterongc
Jun 11, 2013 12:47 PM
