Parts for Chinese Quad??
Old Apr 22, 2020 | 02:55 PM
KingofKossuth's Avatar
Default Parts for Chinese Quad??
I recently acquired what I believe is a MonsterJoe Mojo Pro 80 quad. It won't run and I've been trying to diagnose. It gets spark and I'm getting fuel going to the carb. I did put fresh gas in as well. When I pulled off the carb and tore it apart I didn't see much fuel in the bowl. I cleaned everything out as best I could. The needle float valve was pretty gunked up and at first I couldn't blow air through the fuel intake After I cleaned it I was able to do so. Anyway, I put it all back together and still no dice. I tried putting some gas in the cylinder and it will fire, but when I turn over the engine, nothing. I wasn't able to take the carb completely apart because several screws/pin heads were tore up and I didn't want to ruin it. I'd like to buy a carb rebuild kit, but I can't find anything online.
A) Does anyone have any advice?
B) Does anyone know where I can buy parts for a carb for Chinese quad.
C) There are two wires running to a module mounted on the side of the carb, what is this? Some kind of electric choke?
Thanks
Old Jul 17, 2020 | 06:30 AM
Bryan Baker's Avatar
Default Did you figure this out?
I also just acquired one of these “Monster Joe Moto Pro 80” China quads.
From the Research I’ve done, It has a gy6 engine.
Mine unfortunately came without a carburetor and intake hose. Would you mind sending me a picture of your setup on top of the engine and any other tips?
Happy to share what I know in return also.
Tomtom86
Aug 7, 2024 07:40 PM
Hunter44
Oct 5, 2019 08:09 AM
Yoakum
Ask the Editor
12
Mar 6, 2019 12:11 AM
RedneckSportsman
Mar 6, 2018 11:58 PM
250-man
May 21, 2009 01:03 AM
