Lost All compression, Can't Access Sparkplug - Baja 400 Wilderness
Sounds super amature but does anyone know how to get to the spark plug without tearing a Baja 400 wilderness apart?
I was just cruising around the yard when I lost all compression, pulls over like nothing but no rattling sounds.
First thing I wanted to check was to see if the sparkplug fell out but I can't even see or get to the dang thing.
Looking for advice on it!
I don't know that model/make at all but on many quads you need the special plug spanner in the toolkit to undo the spark plug. Follow the HT lead and remove it at the plug end (often easier said than done) then poke the special socket down the hole.
I can sort of see the sparkplug but looks like I have to remove the gas tank and a ton of plastics to get to it. Service manual makes it look like it's right there.
It's probably really bad designed.
Mainly looking why I lost all compression.
Thank-you for your advice, much appreciated.
