Brake Pad Change
Old Aug 9, 2011 | 09:29 AM
raceman3's Avatar
Default Brake Pad Change
I have 125cc Coolster that is in need of new brake pads. Has anybody changed them before and if so is there anything I need to be careful of? Do I just remove the caliper and replace the pads?
Old Aug 9, 2011 | 09:48 AM
Jaster94's Avatar
i'm not familiar with your quad, but if the caliper is like the ones on the chinese gokarts and some other quads, it's not much different than your car's brake caliper. i've changed mine on my gokart and it only took a few minutes. fairly simple. after change out, bleed it/pump it up. double check brake fluid level. it should be fine.
Old Aug 9, 2011 | 12:29 PM
raceman3's Avatar
Do they use regular automotive break fluid?
Old Aug 9, 2011 | 03:27 PM
Jaster94's Avatar
all of my quads use DOT 4. i don't know the difference between 3 or 4, but the manuals for mine call for DOT 4
Old Aug 10, 2011 | 07:14 AM
raceman3's Avatar
Thanks
STLyamwar
Jul 25, 2020 04:44 AM
Cummins Driver
Sep 11, 2019 01:22 PM
mattcraig1
Aug 19, 2015 03:48 PM
Stirling
Aug 9, 2015 01:49 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
