Kill switch issue at cdi
Have a 110tao tao that wasn't running. I ran through the electrical and found the issue (stator). Unfortunately for me that was the last thing I checked and ended up over troubleshooting prior to finding issue https://cimg5.ibsrv.net/gimg/atvconn...453669ca44.jpg
by attempting to unplug the kills witch wire at the cdi. It runs but now it will Not shut off. I figured by having a key that I'd sti be able to use it. Nope. So now no safe way to turn bike off. I tried to plug the kill switch wire back in through the white box and then into the CDI but the little spot where the kill switch came from is messed up so it does not fit. How can I bypass this mess, if even possible? Thanks! |
Yes, put a switch in a wire from exciter coil on stator, or trigger coil, so it cuts power to CDI and shuts engine off.
