HotCams 2 w/springs and High Comp piston
Old May 15, 2003 | 02:49 PM
Hiram's Avatar
Default HotCams 2 w/springs and High Comp piston
I was reading the instructions that came with the cam and it says something about having to have the center intake valve/guide machined down, what do they exactly mean, has anyone that is using this setup know what they are referring to?
Old May 15, 2003 | 03:38 PM
RacinJason's Avatar
The center rocker carries more geometry causing a slightly higher lift at the valve...with some raptors the keeper may actualy damage the seal...
solution is to "machine" lower the surface hieght of the guide just slightly
I did it with a cut-off wheel on a small dremel...
doesn't take to much
Old May 15, 2003 | 03:48 PM
Hiram's Avatar
So it's the guide that needs to be reduced down? How much do you estimate you cut on yours, and how do I test if OK?
Old May 15, 2003 | 08:48 PM
RacinJason's Avatar
To test if its ok...finish building the motor and start it...if it takes out the seal it will smoke like a stuck pig,
or if you want you take it down regardless and know it won't be an issue
Hotcams sends the measurement don't they? I cant remember how much...I think it was about half the tapered portion.
Old May 15, 2003 | 10:29 PM
RAPTORAZ's Avatar
I talked to Hot Cams about it today. They said very few Raptors will have this problem. Only 4 out of every 100. They also said that the worst case scenario is that it'll consume a little oil. All that's needed for clearancing is 1mm.
Old May 16, 2003 | 12:44 AM
Hiram's Avatar
So I'll just take it down just a bit thanks
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
