bent valve on a lakota
Old May 15, 2003 | 05:02 PM
antix's Avatar
Default bent valve on a lakota
my lakota quit on me a couple of days ago and had no compression so i pulled the head and found that the exhaust valve was bent. it looks like it was just barely comming in contact with the piston. was it doing this because the timing was off? also when i get the new valve is there anything special i should do to get the timing right so this doesn't happen again?
Old May 17, 2003 | 05:07 PM
risonite's Avatar
Unless you have made a radical cam change, milled the head, or something of this nature, your lakota must have 'jumped time'. If this is the case, you'll need to inspect your cam chain tensioner and guides then replace the cam chain and valve.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
