Just changed belt and put in black spring, but now.....>>
Old May 15, 2003 | 07:53 PM
lackdog's Avatar
Default Just changed belt and put in black spring, but now.....>>
Hey all. I just changed the belt and put in the black spring on my 2002 P650, but now when I go into low gear and give it gas and let off it clicks like a ****. I am assuming this is the infamous clicking that plagues the P650 because of improper linkage adjustment, but it never clicked B4 and now after I changed those 2 things it does. Does anyone have any ideas why all of a sudden its clicking? Also would appreciate any tips on adjusting the linkage. I read Nyrocs site and the manual, but ya never know if you guys got tips. Thanks
Old May 16, 2003 | 09:51 AM
Scotia650's Avatar
Definately shift linkage. Installing the rear spring and belt probably put enough tension on the secondary clutch to cause your problem. We did the same changes to one of our bikes and had the same results. Did a quick adjustment on the linkage and problem solved. Follow nyrocs instructions and you should be fine. Hope this helps.
Old May 16, 2003 | 03:01 PM
lackdog's Avatar
Yeah I adjusted the linkage. Piece of cake. Everything is fine now. Thanks
toonces
Jul 31, 2015 09:27 AM
ghost civic
Jul 27, 2015 03:15 AM
Schneider
Jul 24, 2015 05:05 PM
trouttracker
Jul 20, 2015 11:54 AM
Mphillips
Jul 2, 2015 07:20 PM
