Banshee jetting for Pro Circuits
Old May 15, 2003 | 11:00 PM
SykoQuadRider's Avatar
Default Banshee jetting for Pro Circuits
I just purchased a Pro Circuit exhaust and K&N ProFlow for my new Banshee. I live in St. Louis Mo and was wondering where I should start off with Jetting. I did not buy Jet Kit planned on just going to Yamaha and buy some factory
Old May 16, 2003 | 12:09 AM
bansheeguru's Avatar
What jet is in it stock? Are you going to be running with the airbox lid on or off?? If you run no lid I would probably start at 180 and go from there depending on how the quad runs and what the plugs read.
Old May 16, 2003 | 12:47 AM
My99Banshee's Avatar
Stock is 200's, I would start a 260's and go from there, I'll bet you'll be at 280's when dialed in probably! And change the pilot jets from 025's to 030's, My Banshee it running 340's mains and 035's pilots
with Pro Circuit pipes with alot more goodies in Michigan, Your area my be different depending on altitude and sea level affecting jetting I hope this helps you.
Old May 16, 2003 | 01:19 AM
lowriderb1997's Avatar
you sont need to change the pilots till you get different needles, you will probably be about 270 or 280's at sea level you would probably be around 300or 310's. later
Old May 16, 2003 | 09:16 AM
Ernie660R's Avatar
Go will 300 mains, third clip on the needles.
ReconBayou
Oct 31, 2022 05:37 PM
Sw00p
Sep 24, 2015 02:50 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Brandon400
Sep 5, 2015 08:44 PM
