This $uck$
Old May 16, 2003 | 04:06 PM
hinglbyds's Avatar
Default This $uck$
I know this has been said many times...............[img]i/expressions/face-icon-small-disgusted.gif[/img] We are to limited on aftermarket parts:l..................The aftermarket parts that are available are way to much $$$$$$$$$$ compared to other quads[img]i/expressions/face-icon-small-sad.gif[/img]
I understand the mfg's point, but it still bites!!!!!!!!![img]i/expressions/face-icon-small-sad.gif[/img];
I just called a local mfg, I am looking at all the options for A-arms, Swing arm, front and rear shock. I did a forum search and I'm still not clear on the better choices. So I printed all the replies for throan reading material.
Sorry people, just lettin out the steam!!!!!!!!![img]i/expressions/face-icon-small-confused.gif[/img]
This is what I'm looking for:
A Arms, stock length, lighter, Chrome moly, maybe +1 foreward
Tripple rate front shocks, no rezzie, good fit for above
Lighter swing arm, chrome moly or aluminum, stock length, uses DS parts
Dual rate rear shock, rebound, compression adjustable w/ rezzie
Old May 16, 2003 | 04:12 PM
bassetboy55's Avatar
Default This $uck$
i bet a 400EX, or raptor would end all this madness for you. Im just kidding, i was dead set on getting a bomb, and after looking around for dealers close to home, and pricing aftermarket things, it was all just too expensive......
good luck man
Old May 16, 2003 | 04:25 PM
guardinangel2's Avatar
Default This $uck$
ebay is your best bet for good cheap parts for quads.
Old May 17, 2003 | 02:41 PM
OBSESSED's Avatar
Default This $uck$
If you need all that then you need a different quad dude......[img]i/expressions/face-icon-small-wink.gif[/img]
Old May 17, 2003 | 03:57 PM
hinglbyds's Avatar
Default This $uck$
Thanks for the reply people...
Dez...Thanks for the links. I think the aluminum swing arm sounds good.[img]i/expressions/face-icon-small-smile.gif[/img]
Obsessed...It's not a matter of needin all this or a new quad. I just think I have exceeded the capability of my stock suspension. Plus I would like to shave some weight which = more speed. I will not mod the engine until I have a problem with it.[img]i/expressions/face-icon-small-cool.gif[/img]
Thanks evetone....I'll finger something out[img]i/expressions/face-icon-small-happy.gif[/img]
Old May 18, 2003 | 02:20 AM
BlackHawk's Avatar
Default This $uck$
So which parts are actually more expensive than other quads?
I have never seen anything that is disproportionately more expensive. Shocks - everyone gets the same shake. Engine work is VERY unique to the engine & builder. Exhaust is similarly priced. I haven't seen any different pricing of A-Arms. The swing arms cost about the same.
I'm really not sure where this extra cost would come from. Now if you owned a Banshee, I could see your complaint. Those guys have to buy two of everything relating to the engine.
The only difference I've seen is that many manufacturers are taking longer before they start to work on DS parts since there are fewer of them on the trails. That is lag, not cost.
Old May 26, 2003 | 01:01 PM
hinglbyds's Avatar
Default This $uck$
DS..Hi compression piston...$249.00 (kit w/ piston, cams & gaskets $475.00)
Crapter... Hi compression piston (kit)...$159.00
EX...Hi compression piston(440kit)...$320.00
Z400...Hi compression piston (kit)...$159.00
This is just some of the items I have seen. If I had more time I would post the rest.
It don't really matter, I will keep my DS, It's awsome and dependable. I will just mod when I have the $$$, and I will make some more of my own parts.
Old May 27, 2003 | 03:59 AM
ThePunisher's Avatar
Default This $uck$
Works Triple rates 5/8 shafts $600.00
Works revalve rear shock, You can't get a better shock for the back end. $200.00
TVI Aluminum Swingarm, $700.00 Best bang for the buck definatley!!
Strong Arm A-Arms, $500.00 full set. Nicest and Strongest A-Arms I have ever seen to date.
Old May 27, 2003 | 04:13 AM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
Default This $uck$
winning races at dumont???????????????? PRICELESS
Old May 27, 2003 | 11:56 AM
Default This $uck$
HAHAHAHA!!!!!!!!!!!!!!!!!!! LOL That is is snappy one there Mario.[img]i/expressions/face-icon-small-happy.gif[/img]
