Raptor reverse?????
Old May 18, 2003 | 09:51 PM
XtremeRaptor's Avatar
Default Raptor reverse?????
I just noticed that my Raptor will go into reverse without using the reverse lever!!!!!! Anyone have any ideas on what's going on and how to fix it? Thanks in advance everyone!!!!!!!!
Old May 18, 2003 | 10:27 PM
sixsixT's Avatar
I imagine you allready checked to make sure the cable is adjusted properly.
Old May 18, 2003 | 10:46 PM
wshrdskin's Avatar
Extreme, didn't you recently do a tranny rebuild? Did you get the shift forks and reverse fork in the right grooves on the shift cam?
[img]i/expressions/face-icon-small-blush.gif[/img], OOps!! LOL, why would you do that to a 2002. LMAO
Old May 18, 2003 | 11:12 PM
I had an engine rebuild done. It runs fine, real strong!!!!!! I was just messing around today and while downshifting I discovered that reverse will engage without stepping on the rear brake and turning the lever!!!!!!!!!!!!!!!!!!!!!!!!!!!! Reverse seems to work fine too. I was just concerned as to what could be causing it!!!
Old May 18, 2003 | 11:34 PM
wshrdskin's Avatar
Since you didnt split the cases , Did you? then my guess would be a mal adjusted reverse lever.
Old May 18, 2003 | 11:51 PM
GYTR's Avatar
Mine did that once. I just wiggled the reverse switch thing and worked fine ever since.
Old May 19, 2003 | 12:20 AM
Wash- The cases were split!!! (I had a Carrillo rod put in.) But I honestly think it's the reverse lever being mal adjusted!!!!!( I hope!!!!) I'll check it out again tomorrow and post back!!! Thanks for the help guys!!!!!!!!!!!!!!!!!!! Xtreme
Old May 24, 2003 | 03:43 PM
Just wanted to tell sixsixT and Wshrdskin that it was the cable that needed adjusting!!! Thanks again for the help guys!!!!!!!!!!!!!!!
Old May 24, 2003 | 03:47 PM
wshrdskin's Avatar
Excellent, gotta love those easy fixes. [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 24, 2003 | 04:49 PM
sixsixT's Avatar
Mucho exellente[img]i/expressions/face-icon-small-smile.gif[/img]
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
