HELP ELECTRICAL PROBLEM!
Old May 21, 2003 | 10:15 PM
yellowexracer's Avatar
Default HELP ELECTRICAL PROBLEM!
On the weekend my ex was burning out fuses so we took it apart and found that 2 of the accessory fan wires were touching, so we taped everything up and it worked fine.
Now whenever I turn my highbeams on everything goes dim and you can see the front light bulb elements glowing, this is with a 30amp fuse cuz it blew the 15 and a 20.
Has anyone every had this happen?
Old May 22, 2003 | 08:27 AM
dzzy's Avatar
You have another short circuit somewhere. If the low beams are fine, it would have to be somewhere between the handlebar switch and the high beam bulb element. Honda usually uses a solid blue wire for high beam. Take the screws out of the handlebar switch and get it away from the handlebar and see if it works. Also, anyplace that wires have to move when you turn the handlebars is worth a look. Look for wires that are melted together through the insulation, or bared and touching a ground.
Old May 22, 2003 | 11:03 PM
I found that right when the blue wire goes into the left headlight it was frayed.
Old May 23, 2003 | 07:39 AM
dzzy's Avatar
congrats yellowexracer, ya fixed it!!
skinnyr6
Aug 25, 2023 02:18 AM
TheHood
Jul 26, 2015 09:51 AM
Chuck188
Jul 17, 2015 02:45 PM
Unzzy66
Jul 11, 2015 10:01 PM
ranvette
Jul 4, 2015 06:13 PM
