How do you make it so its always in over ride?
Old May 22, 2003 | 12:02 AM
Polaris69's Avatar
Default How do you make it so its always in over ride?
Ever since i put my pipe on my tblazer, my reverse has been pretty worthless, so im always reaching for the yellow button. Theres a way to make it so its always in over ride, i dont rememebr how though.... please help...
Old May 22, 2003 | 12:20 AM
BigBadScrambler's Avatar
I dont know what color wire it is on the TB. But, all you have to do is follow the wire from your override button and disconnect it from its connector under the cowl.
Old May 22, 2003 | 08:14 PM
Polaris69's Avatar
yea, my brother showed me right after i posted this but thanks for replying anyways.
Old May 22, 2003 | 11:25 PM
No problem. Did you try the skull shift **** yet???[img]i/expressions/face-icon-small-cool.gif[/img] I works and looks sweet[img]i/expressions/face-icon-small-happy.gif[/img]
Old May 23, 2003 | 12:01 AM
engine9680's Avatar
skull shift **** where did you see it ? link?
Old May 23, 2003 | 12:09 AM
I put a skull shift **** on my scram Here It is $15 at AutoZone. It is really cool. You push a botton on the side and the red eyes light up. It was even easier to install. Jusat remove the old shift **** by popping the cap off and removing the screw. Then slide the new skull **** on. It fits perfectly on the rod and you don't even have to grind the bumps off the rod. Its held in place turn turning a screw on the back that clamps it to the rod.
Old May 23, 2003 | 12:11 AM
I put a skull shift **** on my scram Here It is $15 at AutoZone. It is really cool. You push a botton on the side and the red eyes light up. It was even easier to install. Jusat remove the old shift **** by popping the cap off and removing the screw. Then slide the new skull **** on. It fits perfectly on the rod and you don't even have to grind the bumps off the rod. Its held in place turn turning a screw on the back that clamps it to the rod. I will try yo get some better pictures this weekend. I just painted my grill an aluminum color to match the renthals.
Old May 23, 2003 | 08:39 PM
Polaris69's Avatar
no i havent yet, the only place ive found that sells them is out of stock so ill have to wait. BTW you have a really sweet scrambler.
Old May 24, 2003 | 01:44 AM
Thank you . I love the new blue and yellow on your TB. I have been debating on going with metallic blue or all black for new plastic. I think the black will look best.
Old May 24, 2003 | 03:42 PM
Polaris69's Avatar
Yea, go with black, that would look the best. When are you planning on buying that?
