help wheelie a 300ex
Old May 22, 2003 | 08:23 PM
LILJOSH's Avatar
Default help wheelie a 300ex
Yeah i been rideing a 300ex for a while i can get it in the air a little bit. am 13 70 pounds can any body help me
Old May 22, 2003 | 08:30 PM
markbanger's Avatar
put it in neutral and when you go to shift hold up the shifter with your foot and give it some gas and then let your foot down and hold on.
Old May 22, 2003 | 09:30 PM
300exRiderJay's Avatar
300ex hhas a cluthc so you cant do that. Just practice in 2nd gear. I can ride them for ever. First push down on the handlebars to preload the shocks and then lift up and gas it while throwing your butt on the seat. It shoot come up relatively easily. You will get it in ten minuites.
Old May 22, 2003 | 09:41 PM
wait a second. ARe you 13 years old 70 pounds or did you make a typo writing an extra 0 and a space. Because if you are 70 pounds the only way you are gonna be able to get it up to the balance point without overrevving to ride one is too find a bump or something.
Old May 23, 2003 | 03:08 AM
FarmStud's Avatar
Just put it in second push the throttle and pull up on the bars, or shift from first to second and pull up. If you want to cheat a little kneel on the seat or stand on the grab bar and hit the gas. Just takes a little practice to get good.
Old May 23, 2003 | 01:39 PM
JoshCVBz's Avatar
Even if you are only 70 pounds you should be able to clutch it up from a dead stop with no problem. Bring it straight up to the Balance point and ride it out...Practice and you'll be able to bang through the gears also. Wheelies are simple.
-Josh
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
