snow plows
Old May 22, 2003 | 11:52 PM
greasmky's Avatar
Default snow plows
i'm wanting to know if anyone can tell me where the the plows connect to the bikes ?do the connect some where on the front end or do they go further back on the frame. i'm going to make one and just wondered how the fatory ones mounted. thanks ahead of time for any replies.
02 375 4x4
custom bumper(made myself)
itp589
2000# winch
Old May 23, 2003 | 03:22 AM
mudblaster's Avatar
Default snow plows
thay bolt on just under the running boards you use the same holes your running boards do but you need a half inch longer bolt . the bracket itself is a peace of angle iron with two tabs hanging down about a 1/4 " apart with a hole driled through both tabs. then all you do is build the blade so that the arms have tabs on the ends with a hole in it then slide the arms under the two brackets and the tabs on the arms go between the two tabs on the two brackets [one on each side] then if you have a winch you use that to lift and lower the blade and if you dont you make an arm to lift and lower the blade. maybe go and ask the local cat dealer if he has some pictures of the blade and brackets and you'll see what i mean.
Old May 23, 2003 | 03:29 AM
mudblaster's Avatar
Default snow plows
ps. i will take a few pictures of mine for you and i'll post them for you to see. ok . i work friday and after work me and a bunch of guys are going rideing so when i get home i will take the picks and try to get them on for sat for you to see if not sat sunday for sure.untill then hang loose.
Old May 23, 2003 | 08:34 PM
greasmky's Avatar
Default snow plows
thanks alot mud blaster that will help out a lot i'll take pics of mine when its done thanks agian
Old May 23, 2003 | 11:52 PM
ecorman1's Avatar
Default snow plows
You'll never make it as cheap as the manufacturer. But if you have it in your head that you have to do it-- so be it... You'll be fixin' it after the first plow...
IMO
Chuck
Old May 24, 2003 | 12:27 AM
bearthunder's Avatar
Default snow plows
Hey greasmky, I don't know for sure if this'll help ya but take
a look at my pictures.
Old May 24, 2003 | 02:20 AM
greasmky's Avatar
Default snow plows
Thanks for the pics bearthunder. I see Polaris goes all the way back to the ball hitch. I think I'll go to the frame like the cat mounts. As far as the reply to ecorman1: I have access to metal and cutting edges. Also rember that the word "Manufacture" means a "MAN" made something. I am man, let me show you what I can make! I've made my own custom bumper for my cat and more bar-b-que pits than I can count. Have welder and tourch will manufacture!
Old May 25, 2003 | 02:01 AM
ecorman1's Avatar
Default snow plows
I hear ya Grease... You go BOYEE! Wouldn't stop a man on the move who knows his bearings. I have welder, mig and lots of want to be. Problem with most of us is, we have more time than money. Thou I'm old, I still have more time... Good luck with all your projects. We'll be watchin'.
Chuck
Old May 26, 2003 | 07:28 PM
mudblaster's Avatar
Default snow plows
greasmky -----i dident forget. I took some picks with my digatal camera but they were to big to put on my page so i will take some more today and put them up tonight. i would have done it sooner but i was on nights i finished this morning plus i swamped my bike on saterday and i bin working on it in between work and sleep.i'll get them up for you tonight
shimanok2
Jan 29, 2016 07:37 PM
Irishman301
Sep 23, 2015 01:47 PM
stcspiderman
Sep 13, 2015 05:15 PM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
