Diff oil
Old May 23, 2003 | 10:27 PM
mountainclimber's Avatar
Default Diff oil
What wieght oil do you use in the front and rear diffs on a 2003 400 ACT? Also what are the capacities?
Old May 23, 2003 | 11:08 PM
CatKrazy's Avatar
Default Diff oil
80W90 FOR LIMITED DIFFS
WHAT DO YOU MEAN CAPASITY,HOW MUCH DO YOU PUT IN IT? FILL IT UNTILL OIL RUNS OUT OF THE HOLE. YOU SHOULD BE ABLE TO SEE THE OIL LEVEL WHEN YOU UNSCREW THE PLUG
Old May 24, 2003 | 05:04 AM
DaveB's Avatar
Default Diff oil
75/90 synthetic. The synthetic oil resists the effects of water contamination much abetter than standard. Of course......if the bellows system (non-vented) works as it should, this is not an issue.
John Reed
Sep 9, 2015 03:46 AM
Dan Newberry
Aug 30, 2015 09:42 AM
Findlay Tulloch
Aug 25, 2015 05:00 PM
Haakon
Aug 24, 2015 01:54 PM
Sportsman850
Jul 31, 2015 04:25 PM
