Carb troubles 300EX
Old May 27, 2003 | 05:55 PM
Airman01's Avatar
Default Carb troubles 300EX
Hello guys,
My plug is fouling very fast on my 300Ex , it has a 11.5 to 1 piston and a web cam in it. Is it the rings or a carb jetting problem? The motor has low hours on it.
Old May 27, 2003 | 11:32 PM
fredo's Avatar
Try using a hotter plug.
Old May 27, 2003 | 11:52 PM
mojave300ex's Avatar
If it keeps fouling plugs you are rich or the carb is dirty. Do you have a pipe?? If you do and combined with the piston and pipe you should have around a 132 main and needle on the 4th notch down, and your air screw 2 turns out, if you have it jetted like that your pilot jet should be fine stock. Is your air-box stock?? if not you need to open it up a little and get a performance filter to take advantage of the cam and piston. I would not reccomend running stock exhaust if you are, if so you should run about a 125 main and clip in the middle. I always run NGK plugs, I don't believe in split fire they foul easy and are pretty expensive. Run a NGK D8ES, or even better DR8ES-L. Changing to a hotter plug isn't going to help the jetting much. Good luck and me what mods you have
Old May 28, 2003 | 03:45 AM
FarmStud's Avatar
My guess is its running too rich, unless the plug is oily.
Old May 28, 2003 | 10:14 AM
Airman01's Avatar
Thanks Guys,
But I have another what if question. My son was racing the machine in a MX race and someone landed on the back of him damaging the disks on the White Bros E series pipe. I wonder if the damage to the pipe could cause some of this problem.
Thanks
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
