Removing axle on 96 sp 500
Old May 28, 2003 | 06:25 PM
hduty's Avatar
Default Removing axle on 96 sp 500
ANyone know how to get those darn pins in the axles out?
I need to get out the axle from teh tranny output to the frond diff, the u-joint is really screwed up badly and I can't get the pin out. It looks almost like it's a wound up flat spring or something.
pleas help
Old May 28, 2003 | 08:46 PM
NCScrambler's Avatar
If it is the one I am thinking about, you just have to yank it reallt hard and it will come out. It should be a spring type clip if that is the one.
Old May 29, 2003 | 12:09 AM
hduty's Avatar
No I think your talking about the CV? that has the round snap ring like thing? Not sure.
It is like a pin that is insterted and needs to be driven out. Same deal that is holding the front CV shafts to the differential.
Old May 29, 2003 | 12:38 AM
WhoDatInDaMud's Avatar
Roll pin remover tool - or a pin punch. It is a roll pin.
Old May 29, 2003 | 12:54 AM
hduty's Avatar
Ok, is it supposed to just pound out, cause I beat on it for awhile and I got a piece of it out, but there is still a piece in there.
Old May 29, 2003 | 01:22 AM
OK, my fault, yes I was talking about the cv joint. The pin you are talking about, yes just need a punch to punch it out. It may have broke when you were pounding on it, should come on out, the rest of it.
Old May 29, 2003 | 02:18 AM
pest44's Avatar
Check out these threads.
Roll pin
Roll Pin II
Old May 29, 2003 | 10:15 AM
hduty's Avatar
Thanks! Looks like it's just time to start pounding again [img]i/expressions/face-icon-small-sad.gif[/img] I'll be sure to get some bolts to replace those friggin pins with!
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
bmark0610
Sep 7, 2015 09:42 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Jason Richards
Sep 4, 2015 06:17 PM
snowolson
Aug 31, 2015 03:51 PM
