Getting piston rings in the cyl?
Old May 29, 2003 | 08:55 PM
KILLERCUDA's Avatar
Default Getting piston rings in the cyl?
Hey guys,
How should i get my piston rings on the piston but into the cyl. Compress them by hand? or get a specail tool? Thanks
Old May 29, 2003 | 08:57 PM
RacinJason's Avatar
A ring install tool is what I used...there are different types about $15-50
head to a local shop and rent/borrow if they will let you...if you braek a ring you'll be pissed and have to wait longer than you have already
Old May 29, 2003 | 09:01 PM
BlueLeader's Avatar
you can use a large hose clamp. loosen it as you slide the cylinder over. Use 2 pieces of wood to keep the piston from going down into the case.
Old May 29, 2003 | 11:50 PM
FISHER1648's Avatar
I just sorta worked them in by hand as I carefully eased the piston into the cylinder. A tool would be the best approach - I probably just got lucky !?
Old May 30, 2003 | 12:34 AM
RepTaR660r's Avatar
All i did was slightly tilt the cylinder to get one side of the ring started, then used a flat head to compress the other side.
Old May 30, 2003 | 09:49 PM
RacinJason's Avatar
Blue leaders way works well
Old May 31, 2003 | 02:49 AM
hondaracer305's Avatar
i think one way is as good as the other
Joe454
Nov 20, 2020 01:19 PM
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
