belt drive in outlander
Old May 30, 2003 | 12:45 PM
manu's Avatar
Default belt drive in outlander
What about belt slippin in uotlander? Any bad experience? I want to buy one. Please let me know it is this a problem.
Old May 31, 2003 | 10:43 PM
95sport400's Avatar
They're just like a snowmobile. The only time you get belt slippage is if the clutches are adjusted wrong or if you're trying to pull heavy loads/mud in high range. Sleds with 150-200hp don't have any trouble with belt drive, an atv sure shouldn't.
Old Jun 1, 2003 | 09:26 AM
sxr6's Avatar
Bomby & Pol are the only CVT belt drives to slip the belt to get under way, thus you do get some belt wear. Once under way there should be neglegable belt slip. By using the proper gear at the proper time ( high vs low range ) you should get considerable mileage out of a belt. My Yam snowmachine uses the same system & at 7,000kms it's on the original belt with very little wear.
Old Jun 1, 2003 | 11:21 AM
dzzy's Avatar
No problems with belts on 100hp sled engines? I work on high output bomb sleds all winter and belt and clutches are a main area of concern. And "blows belts" is one of the biggest complaints I hear all winter long. Countless belts get trashed every winter. Some guys can take them out in a few hundred miles easy, even less under race conditions. Riding habits and clutch align. , adjustment account for some of it, but if your are putting 100+ ponies to it on a constant basis, you better learn how to inspect and replace it. No one around here rides without a spare. With the drastically reduced power of the outlander (compared to sleds), this won't be a problem.
Steeldon
Sep 9, 2015 09:38 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
braap123
Sep 7, 2015 12:58 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
