Platic repair
Old May 6, 2000 | 03:49 PM
trick250rX's Avatar
What is the best way to repair cracks in you plastic? (cosmetically)
Old May 7, 2000 | 11:04 PM
hondatrx300ex's Avatar
yo man!!!!!!! you from MT. P? I'm from winnsboro. what do you ride? how old are you? e-mail me or something. anyways I dunno how to repair you plastic. if its pretty bad it would be easier just to buy some new fenders or whatever. see ya man!
Old May 11, 2000 | 11:27 PM
JD250R's Avatar
Drill holes on both sides of the cracks, about 1inch apart.(line them up side to side) Then take palstic zip ties in what ever color you want and snug up the plastic until the the two sides meet.
Old May 24, 2000 | 05:22 PM
87_250R's Avatar
I have zit ties on the mojave (dont have any cracks or the other quads/trike)and it works good .
Old May 24, 2000 | 06:00 PM
rhino99's Avatar
Have it plastic welded.
Easy, inexpensive (usually) and looks ok. You can tell there was a crack there, but at least theres not 2 holes, a zip tie and a crack.
Old May 25, 2000 | 12:37 AM
hakmazter's Avatar
I guess that that would look cool if you are into stitches or something. Make sure that you line up the top of the pieces to look best and then glue the bottom side with your choice plastic weld, superglue fiberglass resin, etc... A trick we used was to take some heavy screen (about 2-3" wider and longer than the crack) and take a heat gun and on the bottom side, we would heat the plastic and screen (be careful) and when it got just hot enough, you could use a roller or a screwdriver handle and push the screen into the bottom of the fender. It was pretty solid and lasted a long time. If you do it right, you won't screw up the top side.
salixair
Nov 3, 2015 08:25 AM
firsttimerider
Sep 20, 2015 09:07 PM
johnny1982
Sep 13, 2015 07:41 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
