650 - hesitation @ part throttle
Old Jun 2, 2003 | 11:21 PM
589650's Avatar
Default 650 - hesitation @ part throttle
Old Jun 3, 2003 | 12:59 AM
PRAIRIETWIN's Avatar
Air screw adjustment or dirty air filter, carbs, fuel, fuel filter............................................ .....................
Old Jun 3, 2003 | 07:35 AM
Vforcer's Avatar
Have you made any changes ????? or is it still stock ???
Old Jun 3, 2003 | 08:51 AM
trx450's Avatar
I had the same thing happen. Turned out to be a pinched fuel tank vent line. It had about 6# of clay thrown up on top of the tank!
Old Jun 3, 2003 | 01:14 PM
589650's Avatar
vforcer - engine-wise, it is still stock, module on order, would like to sort out this little stumble before it gets here. trx450 - thanks, I will check vent lines, they do vent into the subframe, do they not? I guess just being pinched could restrict them quite a bit. I did post more info in another post of similar name, this blank one was posted by accident, kinda new to this.
Old Jun 3, 2003 | 08:52 PM
grandorvis's Avatar
Mine did that I tuck the gas tank vent apart and put it back together the way I think it would be. Works fine now..
Eric
Old Jun 3, 2003 | 09:00 PM
Kawi650's Avatar
Watch your sliders in your carbs if it dies after a lot of use then it's time for carb work.
skinnyr6
Aug 25, 2023 02:18 AM
skeets44
Jul 17, 2015 01:04 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
D-Hagz
Jul 4, 2015 02:19 AM
