Banshee mods.
Old Jun 3, 2003 | 11:49 PM
1BigDSRider's Avatar
Default Banshee mods.
My brother has 2000.00 to spend on his motor. What should he get. He already has a +8 swingarm, new power reeds, boost bottle, and T-5 exhuast. Hes wanting to drag race what should he do. Talking to him he would like to get a new cool head, bigger bore and a welded crank. He doesnt want to stroke it but he wants to use all the money.
Old Jun 3, 2003 | 11:58 PM
Batoutahell's Avatar
Lots of options, I would say porting, cool head, that would be about 700 probably.
Or he could do a cheetah setup, the 400 kit is right about $2000. It is a powervalved kit, they make some good power.
Then he could look at suspension and stuff also.
He could do a 4mm stroker with porting and it would only cost him about $1200 and that is with the coolhead, might be slightly more if he needs pistons and rings.
I would not overbore just to go bigger, only when needed.
Bat
Old Jun 4, 2003 | 12:03 AM
Sorry, He just wants to spend the money on the motor. Suspension has already been addressed. Left off that he has a stiffer spring for rear swingarm, axis shocks with rezzies. He would like to get the most horsepower for the buck and alittle reliabilty. He runs C-12 in his raptor so fuel is not a problem. He is planning on port and polishing the head.
Old Jun 4, 2003 | 12:04 AM
Ernie660R's Avatar
4mm stroker crank, porting, and a cool head with 18cc domes.
And if there is any money left get some LECTRON Carbs, man do they work great.
Old Jun 4, 2003 | 10:49 AM
Why the 4mm stroker crank? I know it will give higher revs but what benefit for a reliable motor?
Old Jun 4, 2003 | 12:14 PM
witti's Avatar
porting, stock head work, 34mm carbs, weld crank.
Old Jun 4, 2003 | 01:45 PM
FMF's Avatar
FMF
I would get a Cool Head and the Team Alba 400 Big Bore. I just ordered one for my 00 Banshee.
Old Jun 4, 2003 | 03:51 PM
If you go with the stroke and longer rods it will give you more reliability then just the stroke and stock length rods. I believe it makes the rod angle less severe. I may be all wrong on this, but I believe that is correct.
Basically with the added stroke you gain some cc's. and the long rod helps to take some of the stress off the crank.
When I do mine, I am going to have the domes cut for the stroker and run the pistons out of the cylinders. And of course have the porting done too. I believe with conservative porting on race gas I should be able to get about 75 hp or so. With a little more aggressive porting it should be up about 80-85. Just depends on how agressive your bro wants to get.
If I had about $3000 I would do the cheetah cylinders with the stroke. You get about a 421 out of it. I hear they run real good.
Bat
Kaleb_00
Jun 1, 2016 09:15 AM
JakeXBL
Sep 5, 2015 01:08 PM
greek271
Aug 8, 2015 08:16 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
