TOO MUCH LIGHTING?
Is it possible to have too many lights working at the same time on a Blaster? What harm could it cause? Right now I have 2 headlights and one tail light on my Blaster. Any suggestions, any ideas?[img]i/expressions/face-icon-small-confused.gif[/img]
Ok not to be a jerk since no one else posted I'll help you out. Depending on the wattage of the two head lights you have 1. you will burn up your stator if you are running more wattage than the stock stator can provide 2. You run two bulbs that only draw the amount of wattage of the stock bulb on high beam and you'll be fine. I don't know the exact stock stator output on the Blaster so I can't answer what bulbs you can run. If you want to run higher wattage bulbs check out www.rickystator.com for a rewound stator.
Thanks for the info. I had no idea of this. I do know that when both of the head lights and the tail light are on they seem to be very dim. I will take one of them off until I find out more info about how much wattage my stator can put out.
