300 Prairie hesitates/bogs down only at light throttle
Old Sep 21, 2015 | 10:47 AM
hueby's Avatar
Default 300 Prairie hesitates/bogs down only at light throttle
Hello all, I have a 2000 Prairie 300 4x4 that I've recently purchased.
The problem I'm having is under very light throttle it acts like it is hesitating/bogging down. Then if you wait a few seconds and push the throttle in some more it will instantly rev up and go...then it runs great as long as you keep in the throttle some.
It idles great too, it's just a few seconds when you lightly push the throttle that it acts like it bogs down.
Things I have recently done: Put in new spark plug, changed all oil/fluids, I just tore apart the carb and gave it a good cleaning. Nothing has helped so far.
Is this a carb setting issue or belt problem???
Old Nov 6, 2015 | 11:34 AM
everythingatvutvreviews's Avatar
Check the pilot jet, its the smaller of the two. Take a small (very small) wire and run through it. It doesn't take much trash in there to interfere with this jets fuel delivery.
skinnyr6
Aug 25, 2023 02:18 AM
slowgsxr97
Mar 18, 2022 03:40 AM
coolguy420
Jul 10, 2015 01:17 AM
coolguy420
Jul 9, 2015 09:54 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
