Mudlites rubing Help?
Old Jun 4, 2003 | 05:34 PM
Whit's Avatar
Default Mudlites rubing Help?
I just mounted my new tires and the back left side is rubbing on the shock spring. The side with the break is ok. Any help would be greatley appreciated.
28x12x12 back
28x10x12 frount
02 500 manual
Old Jun 4, 2003 | 05:39 PM
Dantheman3's Avatar
sounds like you got a problem jim. did you get new rims with the new tires. if so i would have tires switched over to stock rims, if you already have stock rims on.... then i would talk to my dealer if i were you.
Old Jun 4, 2003 | 07:09 PM
voodoo's Avatar
lift, offset rims, or spacers. either would fix it id imagine. dont tell the dealer bout the 28s hehe. (well, i wouldnt anyway)
Old Jun 4, 2003 | 09:25 PM
Fango's Avatar
Spacers will do the trick.....
Old Jun 6, 2003 | 03:04 AM
luvthemud's Avatar
hey whit, did you put those on stock rims? I was going to put the same size on my cat but now you have me thinking twice. i was going to put them on aftermarket rims.
Old Jun 6, 2003 | 10:16 AM
CatKrazy's Avatar
wait wait wait!!!!!!!
ARE YOU SURE YOU DIDNT PUT THE WRONG RIM BACK THERE!!!!
BECASUE IF THEY WERE GOING TO RUB ANYWHERE IT WOULD BE UP FRONT.
CHECK AND MAKE SURE YOURE RIMS ARE DISHED RIGHT. I.E FRONT RIMS 6.5'S FOR THE FRONT AND REAR 8.0 I THINK FOR THE REAR.
I ACCIDENTLY DID THIS ONCE AND PUT ONE OF THE REAR WHEEL AND TIRE UP FRONT AND THE FRONT WHEEL AND TIRE ON BACK.
MINE DID NOT RUB AT ALL WHEN I HAD MY STOCK WHEELS ON MY MUDLITES!!
I HAD SEVERAL INCHES OF CLEARANCE BEFORE IT WOULD EVEN COME CLOSE TO RUBBING!!!
Old Jun 6, 2003 | 07:19 PM
Fango's Avatar
CK....why the CAPS man.....check your CAPS LOCK KEY dude!![img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 6, 2003 | 08:21 PM
bbertram's Avatar
WAIT WAIT WAIT WAIT.....hehe
What suspension system do you have? IRS or SRA(solid rear axle)?
If you have IRS you may have done what CatKrazy said.
If you have SRA you will need offset rims or spacers, the shocks on the SRA will rub with mud tires when you mount them on stock rims. How much do the tires rub on the shock? Putting a washer or two on each stud might be enough clearance.
Old Jun 7, 2003 | 12:25 AM
CatKrazy's Avatar
why you buggin FANGO!!!!
Old Jun 7, 2003 | 10:02 AM
Fango's Avatar
not buggin....just wondering whats up with the caps....gets tough on the eyes...thought you might have the caps locked...cuz I've seen it on alot of your posts lately.....[img]i/expressions/face-icon-small-smile.gif[/img]
