400EX Handlebars
Old May 8, 2000 | 03:16 PM
conway400's Avatar
I want to bring my bars up and toward me a little bit. What aftermarket bars do you guys recommend? I am thinking FMF 909s. What should I look (out) for? What advantages will I see other than position? Thanks!
Old May 8, 2000 | 04:45 PM
CEET400ex's Avatar
I run oneal aluminum bars with cr 125 bend i am about 5'10" and this is by far the best feeling bar for the money (60$) cheaper that 909 or pro taper but almost as strong. unless you plan on crashing alot i think they will do fine and they come in polished black red or purple so they look good i think rocky mountain atv has them.
Old May 8, 2000 | 06:16 PM
hot_shoe_cv's Avatar
I would not suggest a CR bend to you if you want a higher rise and more pull-back. I run Renthals with a CR bend and I like them way better than the stock ones which were a higher rise & longer pull back. If you don't ride aggressively then a higher rise & more p/b will probably work for you. I'd suggest you call Renthal America & talk to a tech re what you want & why. They are very knowledgible. I don't have their 800 number available
Old May 9, 2000 | 10:01 AM
JAKOOL's Avatar
Go for the Renthal 400EX bend, they only come in silver or black.
Old May 9, 2000 | 10:09 AM
hondatrx300ex's Avatar
you might go with the renthal 400ex bend but I'm sure they are just the same as stock. the banshee bend is higher and has more pullback.later
Old May 9, 2000 | 04:07 PM
swabbie400ex's Avatar
I have the Renthal 400ex bend and like them.
y2k 400ex- Renthal bars, W/B E-Series, K&N filter
Dynojet kit, DG nerfs
Old May 9, 2000 | 06:49 PM
wcy2k400ex's Avatar
I also have the Renthals in the 400EX bend on my 400EX. They are a lot stronger than the stock bars. I really like them.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
