not sure on valve clearance
Old Jun 8, 2003 | 09:39 PM
01DS's Avatar
Default not sure on valve clearance
i put my stage two on, and am adjusting the valves. My exhaust are .009 and my intake are .006. Is this an ok clearance, or do i need to get different shims?
Old Jun 8, 2003 | 09:51 PM
JMAC650's Avatar
They gap should be .004 to .006
Old Jun 8, 2003 | 11:04 PM
MudStud's Avatar
Well
I am not sure how that works with new cams.. I know stock cams ar ewhat .005 -.007? I would like to know also, I am getting A1/A2 cams..
How does that effect clearance with different duration and lift?
Old Jun 8, 2003 | 11:52 PM
DSHawk650's Avatar
The A1/A2 cams call for .008 to .010 clearance according to the setup sheet.
Old Jun 9, 2003 | 09:16 AM
UBETRUN's Avatar
Error on the loose side until you are sure everything is working fine and you get it tuned. My Hotcams Stage II Raptor gave me fits when I was below .007, intake valves would "float" at anything over part throttle and screw up the vacuum to the carbs. I now have the lash set to .008, no problems.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
